Results 1 to 6 of 6
Thread: Multi-sided machining Tips
    Jun 2010
    Cypress, TX
    Default Multi-sided machining Tips
    I am looking to carve at least 4 sides of a wood block (top, bottom, left, right) on my shopbot buddy (3-axis). Has anyone tried doing this yet? I am using vcarve pro and it seems to only support 2 sided machining natively. I am guessing I need to do this with 2 different vcarve files.
    Looking for any tips or insights both in the software and setting up the machine to do this and maintain alignment.
    I've done it with two, two-sided files.
    Maybe a good read for fixturing for 4 sided?
    https://forum.vectric.com/viewtopic....262895#p262895
    Jun 2010
    Cypress, TX
    Thank you for sharing. I will see if I can adapt something similar to that and make it work.
    Perhaps an irrelevant tip:
    An indexer makes for an excellent hold down device for doing multi-sided machining.
    Jun 2010
    Cypress, TX
    I ended up making a fixed hold down board with a machined pocket. Each cut used the same XYZ 0 point.
