Thread: PRT Standard Table Size Upgrade
    Jan 2021
    Default PRT Standard Table Size Upgrade
    I may have the opportunity to purchase a 2001 PRT Standard 4'x4' CNC.
    How difficult and expensive would it be to expand the X-Axis to 8 feet? Obviously the main C-Channel and X axis angle iron rails would have to be changed. As for the rack gears can those added too or would I need full length rack gears? Is there anything else? Is it hard to change the computer side of things?
    May 2011
    ny
    I would replace the rack with new full length and new pinion gears. Is it the original controller? I have a 2003 and the controller was a dog, upgraded to a prs control much faster and reliable. Software setup for larger table is not an issue.
    Jan 2021
    Quote Originally Posted by Brian Harnett View Post
    The controller has been upgraded to a PRT V4g board
    Do you know of a good supplier for 10 feet rack gears and new pinion gears?
