Results 1 to 10 of 12
Thread: Cutting PVC Edge Finish Help
Hybrid View
    Aug 2012
    Davenport Iowa
    Default Cutting PVC Edge Finish Help
    I have been cutting PVC and am not happy with the edge finish. I know I could do an offset and then a final full depth final pass. Wondering if there is away around that.
    Thickness 1" and.75
    Using a single edge O flue .25 Vortec Tool
    17,000 2.3 in/sec chip .0081
    .1587 cut depth
    I get a pattern on the edge that looks like a cross cut metal file.Should I use a different cutter or different feed/speed? Picture attached
    What do your chips look like?
    Hey Ken,
    I still think that bit is screamin' for more food. Try pushing it up to 3.2 - 3.5. Need to get the chip load up to around 0.012 at least . Also try increasing the depth per pass to at least 0.25, but maybe 0.375. If you can, jump up to a 0.375 diameter O-flute. With that, you'll need very good hold down. Time for a vac table....
    https://www.google.com/url?sa=t&sour...TvjNlL_hM7bKuq
    Aug 2012
    Davenport Iowa
    No sure this is the best way to describe the chips....mouse turds. I will push it harder. Larger bit is a problem thing to squeeze as much out of a 4x8 as we can
    You’re not going to like what I have to say…
    I’ve cut TRUCKLOADS of HDPE and UHMW this last year… I tried everything I know to improve my cut quality including resetting up my machine. (PRT Alpha). The best I can get is when cutting with a 3/8” 2 flute up cut spiral “O” flute bit and a .010” chip load. When I run the same material with the exact same bits and speeds on my customers ShopSabre, the parts are glass smooth.
    Machine mass does enter the equation!
    The best my PRT Alpha can do...
    What my customers machine does at the same settings
    PS:
    I've fiddled with these images to show the cuts better.
    Aug 2012
    Davenport Iowa
    Dang! Steve did you try a .020 off set and then doing the final cut at the exact size? Doing full depth pass
    Yes… a .010” onion skin. It looked the same as my other cuts but without the stepdown watermarks…
    After posting the above photos, I got to wondering how much difference a spindle vs: my PC 7518 would make.
