Results 1 to 9 of 9
Thread: reset error
    Nov 2008
    canton, ohio
    Default reset error
    Stop button is on?
    the remote stop button connected to input #4 appears to be on
    and needs to be checked.
    we keep hitting reset and here a click in control box. the router will sometimes
    run then just shuts down.
    i need to do some continuity tests but struggle with understanding it all.
    has anyone else had this problem and found the solution?
    Garland Tx
    Yes… in my case it’s obviously an issue with one of the microswitches inside the E-stop housing. I’ve been unable to find replacements, so that means replacing the entire assembly. I’ve been too busy (or lazy) to research what I need and bypassed it… not a smart move because keyboard commands to “STOP” seem to be mere suggestions.
    Dec 2020
    From the statement above it sounds like the E-stop button functions quicker than a "STOP" command from the keyboard. If that's true, it would be a wise investment, because my space bar takes about 2 or 3 seconds to shut things down. Is this an accurate assessment?
    Mar 2017
    Default Stop button
    Quote Originally Posted by Postman View Post
    Yes, my space bar stopping is about 3 sec. behind the stopping FYI JERRY
    Garland Tx
    I’m not a programmer, but it seems like a keyboard “STOP” command is put in line behind anything else already sent to the processer. Even when it was working properly, I was hesitant to use the E-stop because you loose X,Y and Z location and program location.
    Open up the E-stop, blow out any dust, spray a good amount of contact cleaner in it and blow dry, check and tighten connections, reassemble and try it again.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
    Dec 2008
    Diamond Lake, WA
    Quote Originally Posted by steve_g View Post
    Love that:
    "keyboard commands to "STOP" seem to be mere suggestions" to stop.
    You're right about that!
    Don
    www.dlwoodworks.com
    Jun 2019
    Quote Originally Posted by dlcw View Post
    Love that:
    +1 to that.
    I keep waiting for the "Are you sure" pop up to appear before it stops when you hit the spacebar.
    >> "keyboard commands to "STOP" seem to be mere suggestions to stop."
    That seems to be a good explanation.
    I'm no expert in the SB internals but from my experience, the stop command (space bar) is simply dropped into the top of the queue for execution. So if the executing command is jogging 50 inches, the only way to get it to stop moving is to hit the big red button. Once the command is complete, the space bar stop will be executed. Potentially, a little late.
    The good news is that if the job is rapidly executing code lines, the space bar stop is quite effective.
    2013 PRS Alpha 96x60x12
