Looking to get a 10hp VFD as I’m hoping to run 220v 1ph to it and use it for a 5hp Colombo spindle. Please PM if you have one for sale. Thanks
That is easy and relatively cheap ... https://www.automationtechnologiesin...7-5kw-10hp-34a
thanks! hoping to get a delta as a direct replacement. I guess I could do a 5hp model as well which is currently whats on it. Have you had luck with that brand? thanks again!
also noted this might be an option for me if anyone has this available for sale: Yaskawa CIMR-VUBA0018FAA (5hp, single phase input)
Just fyi, no matter which one you buy, it will need to be programmed, even if you get the same one you have now. It may be possible to buy one from shopbot that is already programmed. It is not difficult to do, but will require some reading and effort.
Kenneth
