Results 1 to 8 of 8
Thread: Octagon Finial
    Nov 2006
    Lexington, Virginia
    Default Octagon Finial
    I need a octagon finial for a pencil post bed. Top of post is 1 3/8" across the octagon. The finial would be approx. 2" across the octagon. The radius parts are 1/2" radius. I was able to draw it on my cad program. I figure the only way I can make it. Is to make a piece of molding and cut the 8 segment pieces and glue they back together. If any one has a better solution let me know.
    T Fix
    2000 ShopBot PRT 96 CNC Tool
    I guess you could do a molding toolpath, but you’d need to either precut the blank into an octagon or make a jig that would hold it in the proper position. Either way, you’d lose your positioning surfaces as the cutting progressed!
    I’m thinking that cutting the sides flat and mitering them together sounds simpler…
    What do you have for software? With Aspire, create half of it (or create a 2 sided job) and add a square section at the top and bottom that gets left on the blank (uncut) and is used for indexing to cut the other side. Create a 3D roughing and finish toolpath.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
    You could do it as a solid by using an indexer as the hold down. Once a side is finished, manually rotate the fixture with the MB (move B Axis) command and do the next side.
    2013 PRS Alpha 96x60x12
    Lenox High School, Lenox MA
    If you have a table saw look at this description. https://www.woodworkingtalk.com/thre...ble-saw.55809/
    You could make the finial separately.
    Nov 2006
    Lexington, Virginia
    Thanks for the interest. I miss detailed my description of the finial. The bottom part of the picture is top of post. Which is already made, no problem for me. The very top of picture is the finial. Which is about 2" across the octagonal and a 1 1/2" in height. Something very hard to hold while cutting the 8 radiused sides. Thanks again.
    T Fix
    Just for fun...
    Nov 2006
    Lexington, Virginia
    Cool srwtlc! I'm getting some great ideas here, that I hadn't thought about. I still have to figure a way with the tooling I have. Thanks for all the ideas All.
    T Fix
