Results 1 to 4 of 4
Thread: cutting 1.5" pucks
    Jun 2012
    Philadelphia
    Default cutting 1.5" pucks
    getting ready to cut 160 1.5" pucks and an trying to figure out the most efficient way. cutting one circle at a time vs creating a continuous vector.
    also when creating said vector how do I avoid the little nibs on the sides
    "The most valuable tool I have is the experience of others" - Me
    Didn't mention what software you're using, but try using a spiral ramp, and if needed, an approach/depart to the profile. Might just need a depart. If you need a good clean finished edge along with a fast cut out, then you'll need a full depth clean up pass that takes off say 0.015 -0.020. For the spiral ramp, be sure to set your plunge rate the same as your feed rate.
    "It’s easier to fool everyone than it is to convince them they've been fooled" - Mark Twain
    Jun 2012
    Philadelphia
    Sorry V-carve Pro, I'm not so worried about the finish, cleaner is better but they are just spacers. my concern is even using a spiral ramp the machine is going to cut one circle, raise, reposition, repeat. It seams I could save alot of time creating a vector that wouls snake the bit up and down the lenght of my board but honestly dont know if i am overthinking it
    The bit has to pull up to go to the next puck unless you're going to just plow full depth from one to the other. Just use a fast spiral ramp and a low clearance height to minimize the time required to raise and lower the z between pucks.
