Results 1 to 5 of 5
Thread: need a bit reccomendation
    Jun 2012
    Philadelphia
    Default need a bit reccomendation
    cutting 3.75" thick pine. would like to be able to cut all the way through. Will take some messing about to max out my Z but not going to try if i can't find a bit.
    "The most valuable tool I have is the experience of others" - Me
    If you're looking for an end mill that will cut that deep, you'll probably be looking a half inch diameter with an six inch length.
    If all you have is a 6" Z, then you're probably going to be in a difficult situation.
    Jun 2012
    Philadelphia
    yea, thats about what I was thinking. for sure 1/2" shank. I do have a 6" Z but I actually get about 7" and can squeeze a little extra out of it. I found a straight cut router bit with a 3" LOC and can make that work but was hopping somebody might know where I can get something a smidge longer.
    I wouldn't be concerned about going deeper than the LOC with a large end mill. I suggest having a vacuum or air gun in hand when going deep to blow the chips away if they accumulate. In my experience, it hardly matters with the 1/2" end mills. I'd stay away from a straight cut since the chips won't be pumped out. A normal two flute upcut would probably be the best. As long as you can get the end mill over the piece, you should be fine.
    Novato CA
    Amana Tool 51325 Carbide Tipped Stagger Tooth Plunge 1/2 D x 3-1/2 CH x 1/2 Inch SHK Router Bit (toolstoday.com) Do as as coryatjohn suggests OR
    Leave the 1/4" pull the piece from the table flip it over and use a hand held router with
    Amana Tool 47100 Carbide Tipped Flush Trim 3/8 D x 1 CH x 1/4 SHK x 2-5/8 Inch Long Router Bit w/ Lower Ball Bearing (toolstoday.com) There are many ways to skin a cat. ;-)
