Thread: Where to enter probe tip diameter?
    Dec 2015
    New Jersey
    Question Where to enter probe tip diameter?
    I have a digitizing probe (it's not a ShopBot touch probe). In the pdf (https://www.shopbottools.com/ShopBot...izingProbe.pdf) that explains how to to 3D probing, it mentions the "Probe Tip Diameter" on page 11. But in the probe settings screen (see below), there is no field for tip diameter.
    Oct 2000
    Willis Wharf, VA
    If you select the .sbp output version, the tip diameter setting is available because the file is run "as-is". The dxf output is used when there is going to be further manipulation in CAD, so the offsets will be applied based on the probe tip you are using.
