Results 1 to 5 of 5
Thread: Is there a carriage return character in INPUT box text?
    Dec 2015
    New Jersey
    Lightbulb Is there a carriage return character in INPUT box text?
    I'd like to format my INPUT box text a bit by using a carriage return (or line feed). Is there a way to do this in a sbp file?
    Oct 2000
    Willis Wharf, VA
    As far as I know you can't , but must admit to never trying it. I'll dig a little and see what I can find out
    Oct 2000
    Willis Wharf, VA
    Scott...it looks like you are out of luck. The SB3 software expects a string for the INPUT box caption text and doesn't know what to do with any of those kind of special characters.
    Sorry
    Have you tried using a \n or \r character? It might work even if not documented.
    May 2014
    MA
    If you're attempting to test multi-line code the easiest way I found to do it was to use the built in SBEdit tool. You can write however many lines of code you want and run the code right from that utility.
    That input box is OK for just one command, but when testing it always bugged me because what you type in would disappear as soon as you ran it, using SBedit, even for something simple as a one or two line test was way better in my opinion.
