Thread: Need help with a PRS machine
    Sep 2022
    Default Need help with a PRS machine
    After letting the machine set all summer I'm trying to get her going. When I launch home with the head 48" or so away from home, the head stops about 6" from home with the X displaying 0". Once it stops the count becomes accurate again and when reinitialized at 6" away, it will complete successfully. Almost like the count is counting too quickly while moving and once stopped it can catch up.
    Second issue. With the head at home, I launch a project the Z drops down and shuts down the machine with no X,Y movement. Thoughts? Thanks
    Dec 2008
    Diamond Lake, WA
    I would suggest reloading your configuration for your machine. Then run thru all your zeroing routines to make sure everything is synced up.
    I can't speak from experience in my machine sitting longer than a weekend, but I do know that there have been many times since I purchased the machine (2009), I can turn it off on Friday and Monday morning things are all messed up. I'm convinced that the initialization files get corrupted during Friday afternoon shut down.
    Don
    www.dlwoodworks.com
