Folks -
HALP! We were cutting some parts out of MDF when at line XXX in the file, the Z axis pulled up out of the material and the machine hung up, with the #4 input light flashing.
Long story short, we restarted, and had the file crash out in approximately the same location 2 more times. We called SB for troubleshooting, and while we were awaiting a C/B we shut everything down, rebooted and loaded a new copy of the file - no problem - we finished that part and went onto the next.
The problem is back, and worse. We're getting the #4 input light, and when I opened up the control box and re-ran the file we are getting a #3 on the internal LED display. Ryan at SB called back and said that #3 was an issue with "Z" - I've checked the bearings and range of motion travel in XYZ and cannot detect any slop or binding at all. All of the stepper motors are about the same temperature as well. The last time it crashed we got a funny sound just before it raised up on "Z".
I was thinking maybe our emergency stop switch was shorted. I have a spare, so I simply disconnected the old lead and plugged in the new e stop switch - same problem.
We've rebooted several times, and get the "looking for tool" message flashing twice, then we get the yellow box of death. The #4 input light is still flashing.
This machine is less than 2 years old, a PRT alpha with a spindle.
Sure could use some help here.... because, of course, we are up against a customer's deadline.
Thanks!
John & Rose
707 263 5874
