Thread: How to desktop bearings
    Feb 2013
    River Fall WI
    Default How to desktop bearings
    Shopbot say you do not have too but, I hear a sqeak.
    How do you greese them and what do you us?
    thanks
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
    Aspire 8.5, Creo 3.0
    Hey Kyle
    The desktop bearing blocks...right?
    I pretty religiously oiled my rails and wipers about every 40 hrs.
    Originally used wheelchair(sewing machine) oil, but 3-in-1 now with no difference.
    Radio button set at 0,0 and 24,18 and then place 3 drops in groove, and then press radio buttons to cycle it evenly, then wipe excess off on the whole rail.
    Z-rail I lower it down all the way, oil at top in both grooves, give oil a chance to go down rain, and then cycle a couple times.
    Try that and see if excess oil on X or Y is discolored rusty?
    I've only ever had the Zs off to the the 5.5" Z retrofit.
    Mine the grease looked good, but the Northern machine we had to take back had been serviced with WD-40 and all the bearing fell off the Z-blocks unlike mine.
    Had to repack those bearings with Phil Wood(sealed bearing bicycle grease) , and last time I checked with the person sold to it was great.
    WD-40 pretty much broke down the original grease.
    Also ala Brady,Never cleaned the bearing wipes off CLOSELY with 90psi.
    With the wheelchair bearings here, if I get rusty oil coming out of bearings, cleaning a couple times is OK, BUT I order new bearings up!
    Good luck Kyle, those bearing blocks ain't cheap I hear.
    Feb 2013
    River Fall WI
    Thanks will give it a go.
    Kyle Stapleton
    Desktop w/spindle
    Potter Pen
