Results 1 to 5 of 5
Thread: Disassembling PRS Alpha 120-60-6
    Sep 2011
    Bowling Green, OH
    Default Disassembling PRS Alpha 120-60-6
    Hi everyone!
    I am moving my shop and need to disassemble my PRS Alpha 120-60-6. The technician who assembled it some 10 years ago is no longer with my company.
    Is there a specific disassembly guide?
    I do have the assembly guide from https://www.shopbottools.com/ShopBot...uideBinder.pdf
    Thank you for your help in advance!
    Erwin
    Jan 2007
    Henrico, NC
    Don't disassemble if possible..... I have moved my 96-60-6 three times with minimal disassembly. First time I removed the lower cross braces and moved it with a borrowed pontoon boat lift trailer, the other two times I bolted 4 trailer tongue crank up jacks on the four corners and wheeled it up on a 16' flat bed trailer. Each time I strapped down the gantry and each move went smoothly. Of course if yours won't fit out the door then........
    Sep 2011
    Bowling Green, OH
    Thx!
    Erwin
    Oct 2010
    TX
    I moved my 120-60 from the Carolinas to Texas a number of years back. I took the gantry off and set it on the bed of the machine ( because it was a long trip and I feared the jarring from the road condition would have the rollers banging on the V rail all the way. I would recommend the same for any trailering and cross town moves). Other than that, I would not disassemble anything that was not really necessary. I loaded mine with a forklift and unloaded with 2 pallet jacks and some blocking. You will probably be able to to do the same.
    Monty
    Sep 2011
    Bowling Green, OH
    Thx!
    Erwin
