Machine stops midfile only when spindle is running
We run a PRT 96 48. It recently began stopping in midfile. The display stays on the gcode line that it is cutting when it stops. We have to use the end task tool to get out of the file. As we troubleshoot we noticed that it doesn't stop when we air cut with the spindle not running. It will stop within 30 seconds when you start the file with the spindle running. Anyone ever had that happen?
- You may not post replies
- You may not edit your posts
Forum Rules
