Thread: Reset default settings
    May 2023
    Default Reset default settings
    Hello,
    We have a 48x96 Alpha here at our 757MakerSpace here in VA. We keep having members change the default settings and not changing them back, is there a way to automatically set the application to reset the settings back to default once the computer is rebooted?
    Oct 2000
    Willis Wharf, VA
    Quote Originally Posted by qsligh View Post
    Hello,
    I don't know of any way to do it automagically in the ShopBot software, but I wonder if it could be done with a Windows Shell script? Create a folder and put the default config file in it, then have a shell script that runs when Windows starts that deletes the existing one and replaces it with the default one?
    If you don't mind if it's not automatic, you can use the UR command to do a reset every morning? The down side is that someone would have to remember to do it, and also be sure that they selected the correct settings file for that tool?
