Results 1 to 4 of 4
Thread: Pinion Gears with set screws
    Jun 2004
    Fuquay Varina, NC
    Default Pinion Gears with set screws
    For sale Pinion Gears with set screws for Standard 4 each and 2 for Alpha. $15.00 each.
    Jimmy
    I’ve never been fired, but, I have been laid off when they were still hiring.
    PRS Standard 48"x96" with PC Router and Aspire 9.008, Cabinet Parts Pro
    www.cncsignshop.com
    cncsignshop@nc.rr.com
    919-802-7477
    Mar 2016
    Jimmy, are these new and how many teeth are on the Pinion gears?
    Jun 2004
    Fuquay Varina, NC
    Quote Originally Posted by GBCraftsman View Post
    These are new. Teeth 4each 25 teeth and 2 each 20 teeth.
    Jimmy
    919-802-7477
    www.cncsignshop.com
    919-802-7477
    Jun 2020
    Arlington, VA
    Sort of on this subject, I need a pair of pinion gears to match those on the long (X) axis of my PRSAlpha, but with a 1/4" bore instead of whatever the stock ones have. I'm constructing a second, lightweight gantry to carry some experimental tools, and I want to use the existing drive system (V-wheel track, rack & pinion drive) on that axis (the stock gantry will, of course, be parked out of the way while mine is in use). My new gantry uses much smaller NEMA 23 steppers that have 1/4" shafts., and all of the motors (X, Y, and Z) will be run by a simple, independent controller instead of the ShopBot's controller. The problem is, I know next to nothing about gears, and despite attempts to measure the existing ones I have had no luck finding any that mesh smoothly with the ShopBot's gear rack.
    So, can anyone give me the specs I need to buy matching gears? If I'm understanding correctly, I need to know the module, pressure angle, and pitch, but the number of teeth will depend on my setup and torque requirements (to be determined).
    Any suggestions will b appreciated, as I have been struggling with this for a while. Thanks!
