Speed control
What command is issued to control the rotational speed of an indexer?
I've been looking, haven't been able to find the answer.
You can use either the MS or VS command, with the B-axis speed that you want in the 4th place after the XY, Z, and A axis values. So if you want to set the B axis speed at 50 degrees/sec using the MS command, the command would be MS,,,,50
You can read about how this works and the differences between MS and VS in the ShopBot Command Reference. It's installed with the ShopBot software and can also be downloaded at https://www.shopbottools.com/ShopBot...les/ComRef.pdf
- You may not post replies
- You may not edit your posts
Forum Rules
