Results 1 to 4 of 4
Thread: File conversion
    Troyer Guest
    Default File conversion
    Have v 3 on 2 computers. On one computer when I go to convert dxf file 3d to sbp error comes up saying file is already open. I can't continue with conversion. On other computer everything works great. All other programs are closed and rebooted computer. what am I missing here.Thanks for all the help here on the board. Don Troyer
    alejandro Guest
    Hi troyer
    I made an Autolisp routune that create the SBP file in order that you select the circles or polylines in any "Z" (arcs and/or lines) and 3dpolylines)
    if you are intersted send me an E-mail
    alexguttaf@juno.com
    bye
    Troyer Guest
    Found that if I use windows explorer and drag the dxf file and drop it on the converter file it converts it fine. Why won't it allow it to convert using the shopbot v3 software.
    Dec 2003
    Panama City FL
    I am also having a problem with getting a "DXF_Gui Run-Time Error '55' File already open" error message after pressing the "Convert DXF File" button on the converter window running Shopbot windows version under Windows XP. Is anyone at Shopbot working the DXF converter problem? I'm dead in the water until it's fixed.
  1. File Conversion Help
    By KTD in forum Part Wizard
    Last Post: 07-11-2012, 09:37 AM
  2. .max file conversion
    Last Post: 10-21-2010, 05:02 PM
  3. File Conversion
    By rayman in forum ShopBot Buddy
    Last Post: 10-18-2010, 09:50 AM
  4. .txt to .sbp file conversion
    By manofariz in forum Archives2006
    Last Post: 12-23-2006, 04:45 PM
  5. File conversion
    By bilbee in forum Archives2006
    Last Post: 12-08-2006, 10:51 AM
