i keep getting the foll error
input past end of file 62
anyone has any idea why?
does shopbot have a error index?
thanks paul
thanks paul
Paul,
Can you post/attach the offending file so we can take a look at it.
thanks Scott i got the problem solved.
the problem was with my usb flash drive somehow
shopbot was not reading it. put the file on another flash drive and everything worked.
is there a brand of flash drive that is considered
very reliable.
i really thought by using a flash drive my storage problems was solved. wishful thinking
paul
Paul,
Most any flash drive should be fine. Be sure that you're copying that file off the flash and onto your hard drive before running it with SB3 (loading the file from the hard drive and not the flash drive). Running a file directly from a flash drive is asking for a problem sooner or later.
Ok thanks scott i have been running directly
from my flash drive.
thanks for the information
paul
