My (PRT96, Latest software, late model DELL driving it winXP) has developed a hiccup at random locations. It SEEMS to be on the X axis only, at all speeds.
To test, I drilled a hole at 400,400mm, and ran a cutting file in the air. Then I went back to 400,400, and found the bit went in about 2mm towards 0. There were many hiccups in both directions so this is probably an average over the whole file.
Frank from SB is helping, but I have done all he suggested and to no avail yet. (Turned off antivirus, checked mechanicals, leads, earth, background programs, greased pinions etc) all seems to be good. I have re-loaded software, and firmware, tried different ramps, speeds, files.
Is my control board failing? Or is a motor failing? Anyone with experience of this problem please feel free to chime in. Of course I am just about to embark on a big job using expensive plastic
Simon
