Results 1 to 10 of 16
Thread: Spindle Auto On/Off
    Aug 2008
    Plympton MA
    Default Spindle Auto On/Off
    I've read over the archives but still can't figure this out. Can someone explain to me (in beginners terms) how I can setup my spindle to automatically turn on/off at the beginning/end of each program? I have a 4HP spindle, and a spare relay on the relay board that came with my air drills, if that factors in. Thanks.
    Nat,
    Do you have the spindle control board that communicates with the VFD that Shopbot sells or one you can make with a RS485 board from here?
    If you do, then all you need to place in your files is SO,1,1 for on and SO,1,0 for off. If you're using PartWorks or VCP, then there's a post that will do it for you.
    Aug 2008
    Plympton MA
    Scott,
    I'm embarassed to say, I'm not sure if I have the control board or not. I'll take look tommorrow, (with the help of a schematic!).
    Apr 2007
    Marquette, MI
    Nat...
    I use a relay connected to output 8 that is a parallel switch to the START button. You can hit [ALT] [8] and switch it on for the file, for the day or enter it on and off when needed into any file or your Vectric PostP.
    PS... turn OP8 on before the OP1 line in the parts file.
    Dont get to liking it too much as you will soon run out of relays!
    Gary
    Aug 2008
    Plympton MA
    Gary,
    I should know, but how would the wiring run on that?
    Between that and the new solenoids for the drills, that pretty much eats up the relays. What about the dust collector, vacuuums... Fine line here between making things easier/complicating things. We'll see how it goes.
    Apr 2007
    Marquette, MI
    Nat...
    I am out of outputs... jonesing for the new board with a few more...
    Put 2 wires into the connectors of the start button. 1 alongside each of the existing. Run these 2 wires to the 2 NO (normally open) (May be a common and NO connector) connectors of your selected relay. If you have the SB board, select the output you wish to operate the relay with by the jumpers.
    Thats it.
    Gary
    Aug 2008
    Plympton MA
    Gary,
    I've attached a pic of the relay board. Do I run wire from each of the start switch wires to each of the termainals on a selected relay? Also, I'm not clear on the jumpers. I had thought that each relay was already assigned a given output. The only jumper I see being used brings power to the relays. Thanks for the help.
    -Nat
    Apr 2007
    Marquette, MI
    Nat...
    Occording to Eds article ( http://www.shopbottools.com/getting_started.htm ) there is a bank of jumpers next to each relay that you use to select which output operates each relay. Look at the 2 that operate your drill. One will be on 5 and one will be on 6. Set an unused relay to 8. then hook the 2 wires from the start switch to the 2 terminals on the relay.
    Sorry about the earlier confusion, I have another brand of ttl board that has different (3) terminals on each relay.
    Gary
    Aug 2008
    Plympton MA
    Thanks Gary. I'll take at the article and also take a closer look at my relay board tommorrow.
    Happy New Year.
    -Nat
    (Can I trade you the 10" of snow we just got, for some time in sunny Fla!?)
    Apr 2007
    Marquette, MI
    Nat...
    You Yankees couldn't handle the weather.
    Happy New Year!
    Gary
  1. Auto Cad and Inventor Files
    By jmurawski in forum Designing and Creating the sbp cutting file
    Last Post: 04-10-2013, 01:06 PM
  2. Auto 0 z-axis file
    By tomp in forum ShopBotter Message Board
    Last Post: 02-16-2011, 12:37 PM
  3. Auto tool changer
    By taylor in forum Variations & Modifications of ShopBots
    Last Post: 04-19-2009, 09:02 PM
  4. Auto run a comand at end of program
    By zeykr in forum Archives2007
    Last Post: 11-08-2007, 05:46 PM
  5. Auto Router-On
    By joelinkous in forum Archives2007
    Last Post: 07-16-2007, 05:18 AM
