Hello - just got my PRS Alpha BT with spindle running and ran my first part file. The cut size is smaller than the part file size and it wasn't off consistently from X to Y (size of part wizard file is 25 x 2.75 but when it was cut it was 20.75 x 2.25).
I'm using the 1/4 inch Onsrud bit. The toolpath is using a 1/4 inch end mill and I even deleted all the toolpaths and recreated them, ensuring I was using the 1/4 inch end mill tool.
I'm using a profile toolpath, cutting on the outside and a 2d clearance cutting on the inside that's also too small.
I then decided to cut 1/2 inch squares that were 1/2 inch apart. They were cut at 7/16 wide and 3/8 inch apart.
This is baffling me. I've looked through the doucmentation over and over and reviewed my drawings until I'm blue in the face! Any suggestions are greatly appreciated!
