How much, if any, movement should there be in the x,y-axis'? When my PRS 96/48 Alpha is "off" there is, maybe, a 1/16" or less of play. I can hear what sounds like metal ticks on each back and forth push/pull stroke. I'm not sure if what I'm hearing is teeth slop or the motor. I have all the motor mounting brackets/plates moved in for the tightest gear mesh possible. (I've checked twice)
I have only cut the sample "open sign" and there are some pretty jagged start and stops during the milling. At times, during the very small "pocket" moves the whole machine really shakes a lot. Is this normal?
