Patrick, search your documentation and this Forum for changing the "Unit Values"
Read your current "Unit Values" off your system and report them here. Then we can suggest what you should set them to.
Okay, Here are my User Values: X=733.386; Y=733.386; Z & A 916.7324 and B=16.000. The table is 48 x 144. I hope this is what you where asking for Gerald. Thanks for the help.
Patrick, from the rough information that your x and y axes move 14 inches when told to move 10, it appears that your x,y "scale" is 1.4 times too big. Therefore you should multiply 733.386 by 1.4 and have a unit value (for the x,y) around 1026
Looking at this table you actually need a unit value of 1018.59 (the closest value to 1026)
I am sure that you can follow this logic through to get the get right unit values for the z-axis as well. (You can't simply assume that the z is also 1.4 times out - you have to measure it)
Caution, it is 7am here and I havn't had my second cup of coffee yet - you might have to divide by 1.4 instead of multiply!
Thanks Gerald,
I will try it out and let you knoe hte outcome.
