I have a PRS standard with a spindle.
When cutting a profile or V Carving the tool pauses for about a second when making a directional change. On a profile cut it paused at each corner. If you are not watching the machine you may not even notice it because the part cuts fine other wise.
V-carving was a different matter. The bit paused way to long and burned the material (maple).
Just wondering if anyone has come across this problem themselves.
All setting are factory except for slow corner speed set to 35. I have used this setting for over a year with good results.
Thanks.
Darren
