I was toolpathing a file today: cut depth/6mm, pass depth/5mm. I expected the first pass to be 5mm, but instead it was 3mm. Is there a setting to change so that the actual pass depth matches the pass depth entered for the cutter?
Normally I'd create a profile for each cut, but I was using tabs, and wasn't entirely clear on how that would work.
