About the second command PW issues in a cutting file is JZ (Jog to Zero) On some of my part files it will (Correctly) say JZ, 0.250. On others it will say JZ, 0.000. Of course on those files the cutter will leave a streak at the zero zero point.
I have tried re-setting the minimum safe depth command each time I generate a cut file, and I have tried to see if it was just in V Carve files or regular cut files. Does not seem to make a difference.
Why is this?
