I am cutting ice so use 100% stepover in area clear. However if you do this, part wizard leaves the last part in the middle uncut. The only way to be sure this doesn't happen is to change the stepover to 50% but it then takes twice as long.
To demonstrate try this. Make a square 1.1in square then area clear with a 1/2in end mill set at 100% stepover. When you press create toolpath it makes one path around the inside of the square but leaves out the 0.1 square bit in the middle uncut.
Any ideas anyone without changing stepover size?
