someone posted this file to be cut with a laser or such. with a bit of editing I got the parts to all cut on one sheet of ply. two knock down tables.
http://www.knight-toolworks.com/pictures/two tables.zip
I should have went to the site and converted it. I have the plugin on firefox but it won't work with attachment links. got to cut a set as soon as I have a spare sheet of plywood.
You're not supposed to have links or save files with a space in the name...
here is a modified version of the file. I goofed and just flipped the second leg and forgot the notch should have been on top. the fellow added the corner reliefs I was going to do.
http://tinyurl.com/2x6pc2
Do you happen to have the sbp. files for these? Nice tables to hold stuff in the shop!
I can make them from the above vcarve file. or give you a dxf file.
DXF would be perfect, as I do not have VCarve Pro yet!
here you go. these are 3/4" ply and you need a 1/4" bit to cut them. outside cuts for all but the mortises in the top and thats inside cut or pocket.
two table dxf file
twotables.dxf (23.6 k)
Nice tables, but I see what you mean about the VCarve file having 2 of the notches in the wrong side. Do you have a corrected VCarve file you can post?
