I am trying to do a easy offset'' x5.0,y5.0 ''I read the phrase FP,mypart.sbp,1,1,1,1,2 ''''I understand the numbers,,,but where & how do I do fp,mypart .sbp ???is mypart the program name of the part being made???
bryan...
You start by either selecting [F]ile [P]art File Load, (from the top left of the console) or the green Load Part File button on the position box. You now select your file from the folder that it is located in, or simply type it in, if it is located in the default SBparts location. You will then see the fill in sheet for that file. Select the options that you want, and then OK.. your file will run with the options that you have selected.
You can also type in [F][P][any partsfilename.SBP][1,1,1,1,2]etc to add parameters without going thru Explorer type folder structure.
Hope this helps, Gary
or just hit enter to get to the folders.
O i didnt know that was for the fillin sheet ,,,,I dont wont to use it because u have to put the off set in each time ...How can u put the offset in to the program???If u move it to the pos. & xy 0 it,,,,it messes up the table croods...Thanks for ur reply Bryan
Bryan...
To run the file in the way you describe, make a master file. Here are the steps:
Open the SB editor
Enter these lines: (replace bracketed with your coordinate data)
M2,[offset x, offset y] (or J2)
FP, [any parts file name.sbp 1,1,1,1,2] (enter your correct parameters)
END
Save the file with your desired name
The file should now run at your location in 2D offset without using the fillin sheet
Gary
Hey Bryan,
For a little more information there's an article in the "Bill's Corner" section of the website that talks about cutting in Offset mode and making master files. It's called "Exploring ShopBot Part Files 2" and is a couple of articles down the page.
http://www.shopbottools.com/BillsCorner.htm
Bill
It looks like I got it finally,,WOW that artical answered so many questions,,,,Thanks to all Bryan
Bill do U have any thing on the typesetter,,,,for changing the direction from writing in x direction to write in the y direction??
Bryan,
Try this program in ShopBot Labs...
http://www.shopbottools.com/LabFiles/FileRotator.htm
Bill
Bill that worked real easy ,,,It is a big help ,,,But can it rotate clock wise around the 0,0 some how ?? Thanks Bryan
Bryan,
There a new version of the Rotator program in ShopBot Labs that lets you pick the rotation angle...positive for clockwise and negative for counter-clockwise. It also adds support for the CG and CC commands.
Bill
