Results 1 to 4 of 4
Thread: Couple of annoying things when toolpathing. Any fixes???
    Sep 2007
    NRC, Winnipeg Manitoba
    Default Couple of annoying things when toolpathing. Any fixes???
    1) When you are toolpathing a job and a toolpath you just created overlaps another vector not yet toolpathed, you can not choose that vector any more. It'll always choose the overlapping toolpath. Is there a way around this or a fix instead of deleting toolpaths and redoing them in a different order all the time?
    2)How do you switch between toolpaths and edit individual toolpaths? Whenever I try, I can only edit the last toolpath created. Even if I physically choose the toolpath I want edited it still always defaults to the last one edited and I basically have to keep deleting toolpaths until I get to the one I actually want to edit or delete.
    Any way around this one?
    Thanks for any help on my newbie-ish questions.
    May 2004
    Home Images Inc, Bel air MD
    BPM,
    I am assuming you are using Partwizard since you posted in the Partwizard thread and not the new Partworks being shipped with Shopbots since around November.
    If you highlight the toolpath in the list right above Toolpath Operations that is the one that will be edited.
    To be able to reselect any polyline instead of the tool path just uncheck the 2D box in the list of toolpaths to the left of the main drawing window.
    Sep 2007
    Awesome, thanks Frank. I figured there must be a simple way around these problems. And yes, I am using partwizard, I didn't even know about Partworks. Is it a better program?
    May 2004
    Yes, Partsworks has replaced Partwizard. Vectric makes Partworks for Shopbot and is said to be nearly the same as there own Vcarve pro. And yes it does much more than Partwizard.
  1. Annoying twitch
    By matt_raymond60 in forum ArtCAM
    Last Post: 10-19-2011, 11:06 PM
  2. Annoying oversight in Aspire
    By dana_swift in forum ShopBotter Message Board
    Last Post: 08-17-2011, 08:57 PM
  3. A couple things...
    By gc3 in forum Folder 2010
    Last Post: 01-31-2010, 10:22 PM
  4. A couple of shop things and blades...
    By harryball in forum Archives2007
    Last Post: 03-04-2007, 11:13 AM
  5. Bug Reports and Fixes
    By kerrazy in forum Archives thru2004
    Last Post: 03-17-2004, 06:44 AM
