How do I find out if there have been any significant updates and go about getting an update to the most recent version of CPPro?
Robert
Robert
Robert.
Email Ryan at http://www.cabinetpartspro.com/
he usually doesnt take long to answer.
Gary
CabinetPartspro has an Update V8.
Cabinetpartspro includes 3 modules: Cabinetpartspro, PartNester and CabinetCad
Cabinetpartspro calculates cabinet parts based on the size of the cabinet box. It produces layered dxf drawing for the parts of the cabinets entered. The dxf drawing includes all the machining features such as shelf holes, dados… .
PartNester will nest and tool path the dxf drawings.
CabinetCad gives you the ability to add or modify the nested dxf parts.
Changes include:
New look
Creates Layered dxf files for nesting
Better nesting
Corner cabinets
Separate settings for each cabinet type
Allows different material for each part
Creates a layered dxf drawing for each part
Nesting shows all cutting features
Setup toolpath template for each layer in the dxf drawings
Ability to add features to the drawings
Video on entering cabinets
http://www.cabinetpartspro.com/Video...20Cabinets.zip
Video on nesting and tool paths
http://www.cabinetpartspro.com/VideoV8/PartNester.zip
If you have purchased Cabinetpartspro within one year, and have not received the new version, please send an e-mail to info@cabinetpartspro.com.
Can you expound more on the Cabinet CAD module?
CabinetCad is a basic 2-½ dimension cad program. You can use it to add or remove features of a cabinet part. After the parts are nested right click on a part and select open dxf, CabinetCad will then open. Once CabinetCad opens you can make your changes and additions. After making changes save the drawing and close CabinetCad. Then all the parts related to the modified dxf will have changed.
CabinetCad is early in its development. It is a cad program specifically for cabinet making. It will have drawing tools like draw valance, flutes, and cabinet side…
Ryan
Absolutely stellar...
/RB
Robert,
Are you putting cabinets in your bathouses?
I am going to upgrade my ccp version soon . Have you built many with this program? How did you like it?
There is an update to CabinetPartspro.
8.5.1 Update includes:
Faster Nesting (tested 60 sheets in under 15 seconds)
Improved nesting
Part rotation
Option for grain direction
Door and drawer sizes
wow,,that is FAST. Awesome Ryan. I like the rotate part option. Door and drawer option is helpful too.
Thanks Ryan,
David
There is an update to CabinetPartsPro.
8.5.8 Update includes:
better nesting
Option to add line numbers in cut file
Option to zero to table or top of material
New add to depth setting for tool paths
Added more user script examples
