Using Copy Program in Tools I probed a 2D file using the base as Z Zero. This produced one tooling path. I would like to make multiple cutting passes using this file starting at 1.6" above base and cut every .2" until reaching 0" which is the base or bottom of the part.
I usually write in the program the FP command calling up the file each .2" but would like to learn a new means of approaching this with Basic programming or Part Wizard. I would appreciate any help.
I have attached a sample file.
Perimeter File
DRS 40_21 PERIMETER.SBP (13.7 k)
