Results 1 to 4 of 4
Thread: CC vs CR
    Jun 2007
    Hampton Roads, VA
    Default CC vs CR
    When you CR you can choose to pocket inside out or outside in. Luvit.
    When you CC you don't get the pocketing direction choices... What up yo?
    Sep 2009
    Surrey, UK
    Isn't the "Outside-Inside-True" parameter the same thing or does the pocket inside/outside on the CR cut in different directions?
    You can tell I never use the Shopbot functions!
    Apr 2007
    Marquette, MI
    Joe...
    Wad up wid dat? Yo gots to be readin da book.
    If you look in the Programming Handbook under the CC or CP command. You have parameters to set for virtually any setting.
    The Short version is on the fill=in sheet:
    Gary
    Jun 2007
    Hampton Roads, VA
    Hmm. It seems that its a different UI implimentation... The man is jus tryin to hold a botta down. Confuzin the issue wit double standards. I sees how it bes now. IK'm all up in dem chips now.
    Word.
