I'm trying to do what i thought would be a simple task but am having problems joining these vectors to tool path. I started drawing squares and snapping to each corner then node edit and remove two sides of the square and and joinging with a line. the line joins all the corners instead of joining the two end points. I then tried welding squares together and can only weld the first two. Any one know the trick to this?
