I've spent a few days testing a new Oriental Motor PK296-F4.5A motor and various Geckodrive stepper drivers. The purpose of the test was to find out whether the PK296-F4.5A stepper motor was a viable motor to use with a Shopbot.
The PK296-F4.5A motor has basically identical electrical specifications with the PK296-03AA motor. Specifically, the Inductance rating is the same. In other words, wiring the PK296-F4.5A or the PK296--3AA motor half-coil should give the same basic response.
Tests showed that it worked. I have four PK296A2B-SG3.6 motors. I connected one of them to a Gecko G202 stepper driver with a 33k current limit resistor and I connected the PK296-F4.5A stepper to another G202 stepper driver with a 33k current limit resistor. Both stepper motors responded identically (except for the fact that the GS3.6 motor has a 3.6:1 gearbox attached).
When I changed the connection to the PK296-F4.5A motor from half-coil to bipolar parallel, the motor ran about 1.5 degrees C cooler. When I played around with the resistor, I found that running the PK296-F4.5A drive and the Geckodrive G202 stepper driver with a 100k current limiting resistor gave me optimum performance before the heat rose to an unacceptable level (75C). (I'm also testing whether increasing the current draw through the motor with a higher resistance resistor and then lowering the power supply voltage to allow the motor to run cooler can be done with good practical results.)
Here's what I've learned:
The PK296-F4.5A motor geared 4:1 with a belt drive and allowed to pull about 4.75A produces a little more than 1,200 oz*in of holding torque, or about 75 lb*in, comparing very favorably to the much more expensive Oriental Motor Alpha 7.2:1 motors and drivers, which produces a reported 80 lb*in of torque.
The Oriental Motor PK296-F4.5A motor responded very well to speeds of over 1000 inches per minute, although I have limited my machine to run at not more than 720 inches per minute.
The PK296-F4.5A stepper with a 4:1 belt-drive and a 1.25" diameter spur gear (25-tooth) gives 0.000490625" per step resolution compared with 0.000654167" per step from the Alpha 7.2:1 motor driving a 1.5" diameter spur gear. (Any figure smaller than 0.003 is most likely going to be lost in the "elasticity" of the machine.)
The tests have indicated that an Oriental Motor PK296-F4.5A stepper motor combined with a 4:1 belt-drive transmission and driven with a Geckdrive stepper driver (I personally prefer the G203v) can compare comfortably with the Alpha option.
Further testing may show that reducing the power supply voltage from 35VDC to 28 - 30 V might allow greater torque at a loss of high end speed. Since I've decided that 720 RPM is the maximum required jog speed, it looks like I can safely reduce the voltage (which will allow the motor to run cooler) without sacrificing torque.
REMEMBER that the title of this post is "ruminations". Do-it-yourselfers might find something to play with. The normal 'botter can safely ignore the post.
