Tony,
My client wants several Vector Art 3D plaques cut that will be 4" x 4".
I have both VectorArt3D Machinist and Cut3D. My question is: After using both programs, with identical bit settings, why is the detail different for each program? Shouldn't the results be the same if using the same bit for each?
I've included both pictures to illustrate this.
These pictures do not do justice but the first elk has it's legs and antlers very much narrower than the second. And as I said before, all bits and program parameters were the same.
The program Cut3D doesn't seem to handle these files very well or perhaps one of the following formats (V3M, PTN, RLF, STL) will produce better results?
Please let me know what format you would recommend when using Cut3D vs VectorArt3DMachinist.
(If you put your mouse over each picture, it will show what program produced it)
Tom
