Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Best tool for trimming / cutting through tabs or bridges for post CNC processing
  1. #21
    Feb 2009
    Rocking Frog, LLC, Cary NC
    Quote Originally Posted by knight_toolworks View Post
    even without a vacuum if you use the right size downcut many plywood and materials can be cut without parts shifting. it's rare when I need tabs for anything. I cut these pretty small parts from 1/8" Russian plywood 1/2 half sheet 30x60 takes 3 hours to cut with a 1/16" downcut bit but the parts stay in place. I added tabs so they would stay in the sheet when I cut the sheet into parts.
    How do you cut the tabs afterwards, Steve?
  2. #22
    cnc routing, portland or
    Quote Originally Posted by asteude View Post
    no tabs I use a downcut bit of the right size so the sawdust holds the part in place.
    here is a sample the circles were cut out of 1/4" bb ply with a 1/8" downcut one pass. the other parts were cut out of 1/8" bb ply one pass a 1/16" downcut bit. This works well but it depends on the plywood/material the size of the bit number of passes. But seldom do I need tabs but it may slow cutting down. but you don't have to clean the tabs off or cut them either.
  3. #23
    Feb 2013
    Vicksburg MS
    I've been looking around trying to find some tab cutting solutions. I'm working a vacuum system, but imagine I will still need to use tabs on occasion and would like to have a good method in place.
    I was thinking back to my earlier woodworking days before I had any of those fancy flush trim bits with bearings. I would just use 1/4" or 1/2" straight bits and let the shaft above the cutting length be the bearing surface on the pattern. It got me by.
    So why not just use 1/4" spiral cutter bits with a short cutting length (like 1/4") in a laminate trimming router to cut the tabs from the top on 1/2" or better material?
  4. #24
    I don't know-Why Not?
    Actually if I am going to use a router and did my object cutting on the bot with a 1/4" bit I don't like having to "shove" a 1/4" bit in a hand router in the slot.
    Although I don't do tabs often, for wood, depending on the thickness and size/shape of the pieces, I may use a router, knife, razor, Japanese dovetail saw, or chisel.
  5. #25
    Feb 2013
    Vicksburg MS
    I see your point about needing to undersize your tab cutting bit, compared to slot size.
    I have been searching for a spiral 1/8" DIA bit with a 1/8" and a 1/4" cut length. I have found some with 1/4" cut length, but not 1/8". The thing I am concerned about is that the machining of the bit extends well past the cut length, which gives you less room for error on the finished surface.
  6. #26
    Jun 2013
    Pasadena, CA
    Don't like to use tabs as well but sometimes still best for small parts, I cut it out with jig saw with fine blade or a vibrating multitool with a slim attachment for sturdier parts or a wood cutting disc on a Dremel for delicate ones. Or, I cut the tab so thin that I can break it out without tearing. I wish I had not sold my scroll saw since that might be the cleanest and least damaging way for small stuff.
    Box Joint and Dovetail Software Here
  7. #27
    I use a 3/16 flush trim bit in my trim router.
  8. #28
    I use a Rotozip to cut my tabs. Since I use a 1/8" sacrificial board under my material, I can set the Rotozip bit to cut just barely through and the tabs and skins cut very easily.
  9. #29
    Oct 2013
    San Francisco CA
    I use a Harbor Freight oscillating tool (used to be called a "Fein Tool" before their patent ran out) with a Bosch 3/8" Wood/Metal blade to cut the tabs, then take it to the table router with a piloted trim bit to smooth them off.
  10. #30
    Jun 2004
    Springfield Mo
    Default Dremel tool cutoff wheel
    A Dremel tool cutoff wheel works well for some items, you want to locate the tabs so they are easy to cut.
  1. Post processing spindle issue
    By groucho in forum Autodesk Fusion 360
    Last Post: 01-08-2017, 03:42 AM
  2. Good Saw For Cutting Tabs
    By Ken Sully in forum ShopBotter Message Board
    Last Post: 04-25-2016, 06:56 AM
  3. Squealing noise when cutting tabs?
    By hipstomp in forum ShopBotter Message Board
    Last Post: 06-30-2015, 09:49 AM
  4. tabs and bridges
    By appliedmodel in forum Part Wizard
    Last Post: 01-11-2013, 06:14 PM
  5. Bridges & Tabs - which one is the final say?
    By knedert in forum Archives2006
    Last Post: 01-25-2006, 05:18 AM
