Greetings,
I need to make some tapered wood legs in two different sizes. The first set (of 6) are 4" high, 2.5" wide at the top, and 1.5" wide at the bottom. Each of these have 4 flat sides. The second set (of 8) are 6" high, 5" wide at the top and 3" wide at the bottom.
I've thought of using my PRT to cut out multiple (trapezoidal shaped) pieces, each 3/4" thick, then gluing them together. This would give me the taper on two sides, but not the other two. Hmm...
Has anyone done this? If so, a quick explanation and/or picture(s) would be greatly appreciated.
(I also have a table saw, jointer and planer in the shop, if that would help.)
Charles
