I wanted to start this thread for two reasons.
1)To discuss various ways that we have come up with to hold down material for cutting, mainly odd or small parts, by use of various jigs or the like. (Happiness is a well made jig that works well) ;^)
2)I have need of ideas on how to hold some 5" x 7" blanks to cut a circular pocket in the middle, trim, radius the corners, and round over the edges of them with an ovolo bit.
Because of not being able to hold them from the top, and vacuum not being strong enough without edge contact, the one way I keep coming back to is to screw them to a backer board using a template for alingment then placing the screwed down group on the table in the same place every time by indexing it. I have to do 700 of these so I'd like to come up with something quicker than two screws in each blank. Anyone have some other ideas?
I'll make my contribution to the jig discussion with my jig for holding blanks for boxes that consist of two 5" x 8" x 3/4 pieces, one is the top with a deep recess and one is the bottom with a shallow recess that gets either a pocket for a badge, knife, etc. My jig is a two-part jig that is sandwiched together. The top layer is 3/4" thick that has 20 shallow 5" x 8" pockets in the top with a slightly smaller rectanglar hole all the way through. This layer is on top of another piece of 3/4" material that has a manifold cut in it connecting all the openings to vacuum from a shopvac. This setup works very good for this type of project with a master file that allows me to place any type of pocket or whatever in all 20 pieces quickly.
So how about it, any other ingenious jigs or methods out there? Any suggestions for my other project?
