Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Alpha 7.2 motors or PK299-F4.5A motors?
  1. #11
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    I just completed the 7.21 upgrade on my alpha and i cut a door sample before and after the upgrade . The difference is incredible . Ill try to post photos , after the upgrade i cut 3/4 mdf 2 passes @7 ips the cut was as good as on a table saw . I used a 1/4 compression bit from centurion tooling and for the groove in the door pannel i used a 3/4 ball nose @4 ips .125 deep and it can go to paint without sanding. Its like a new machine. I would not give a second thought about the shopbot upgrade , go for it .
  2. #12
    Sep 2004
    , Denver PA
    Our satisfaction with the ALPHA upgrade was similar to Gene's.
    Mike,
    If you do the upgrade and don't like it, we'll buy the machine. Only, you need to deliver it.
  3. #13
    , South Jordan Utah
    Now that I've got a guaranteed buyer for the machine, I'm going to go for it ;>)
    The upgrade is too good of an offer to pass on, even if I only replace the two X-axis motors/drivers and the Y-axis motor/driver.
    Somewhere along the software upgrade path, I changed my circle resolution from 0.005 to the factory default 0.05. Setting that back to 0.005 and changing the steps per revolution from 500 back to 1,000 on my 3:1 belt-drive gave me nearly perfect cuts - again. I'm really doubting that changing to the 7.2:1 motors will make my machine perfect, but I won't know unless I try . . .
  1. Upgrade stepper motors on prt alpha 2006
    By mikesicard3518 in forum Variations & Modifications of ShopBots
    Last Post: 02-21-2013, 12:08 AM
  2. PRT Alpha W/Direct Drive Motors
    By CNYDWW in forum Variations & Modifications of ShopBots
    Last Post: 12-29-2012, 04:10 PM
  3. What ohm motors???
    By jzarski1 in forum ShopBotter Message Board
    Last Post: 04-10-2012, 08:51 AM
  4. Unit Values for the 7.2:1 PRS-Alpha Motors
    By richards in forum Archives2007
    Last Post: 09-09-2007, 12:24 AM
  5. Replies: 2
    Last Post: 03-15-2007, 07:26 AM
