Results 1 to 4 of 4
Thread: CRIBBAGE HOLES
    David Marcotte Svc LLC, Cocoa Fl.
    Default CRIBBAGE HOLES
    I am interested in the cribbage boards shown on the forum.
    I am new using part works and cannot figure out how to design the peg holes in a circle.
    I do have an air drill so I was hoping to employ it.
    Thanks in advance for any help.
    Dave
    Oct 2006
    WildWood Mfg.., Ulm Montana
    David
    I have been building cribbage boards for couple of years. The way I build the hole, is this.
    First I draw a circle or oval in VCarve. I cut this Oval at the top and the bottom by using the node editor, leaving enough room for any designs or engravings I place at the top and bottom.
    Then I go into Text and type 1/2 the board of o's. I type 'ooooo ooooo ooooo....etc, until I have either 30 or 60 depending on the board I am building. I then align the letters to the 1/2 oval, telling it to fill the space. Change these to vectors by highlighing, right click, 'Change to curves'. I then go through and delete the outer circle on each of these, to eliminate double drilling. I repeat this for any additional players. I now have half a board, then it is easy to copy and flip that half over to the other side.
    Takes a little time, but that is the only way I found to do ovals. I did figure out how to do circles using circular array, but it never worked for ovals.
    I then drill these holes .22 deep using peck drilling and a 1/8" bit.
    Hope this makes sense. Several steps and takes some time, but after making about 100 oval boards it isn't that bad per board.
    Butch
    Butch, thanks for the information. I will be trying it out this week.
    David
    http://www.cnczone.com/forums/showthread.php?t=19346 do a search as i've seen bunches of cribbage board designs over time
  1. cribbage board holes
    By rseeley13 in forum ShopBotter Message Board
    Last Post: 04-27-2016, 02:03 PM
  2. Cribbage table
    By butch in forum Folder 2012
    Last Post: 10-16-2012, 10:23 AM
  3. Cribbage Boards
    By kartracer63 in forum Folder 2012
    Last Post: 09-18-2012, 12:19 AM
  4. In need of a Cribbage Board
    By t_vandemark in forum ShopBotter Message Board
    Last Post: 12-18-2009, 10:16 PM
  5. Cribbage Board
    By tparr in forum Archives2008
    Last Post: 11-09-2008, 01:13 PM
