Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 58
Thread: Upgrading the PRT-Continued from 2007 Archive!!!
  1. #21
    Dec 2008
    , Richmond Tx
    Wow, I am thinking the trip to california and paying 1500 difference to get my prs and sell the prt was a great deal after watching this take place.
    Kenneth
    Kenneth
  2. #22
    Delray Beach, FL
    If I had seen a PRS with 5hp columbo that I could get for 1500 more than I could sell my PRT for I would have grabbed it too! But I bet with cost of trip added in as well as time away from shop real cost is the most relavent.
    Of course-If I was going to wish I would wish for a Haas with toolchanger! Or since we are implementing e-cab a Thermwood.
    Naah-I would have grabbed the toolchanger that Gary got instead!! I'm just a sucker for Bots.
    Note that much of the delay from conception till now was due to many other priorities along the way.While planning this we also accumulated forklift, Holzer edgebander and sliding table saw, Delta RT31 cabinet saw, and moved to a new shop which needed complete outfitting electrically as well as wall work.
    This project is a pain in the neck in many ways but it is also a load of fun.
  3. #23
    Dec 2008
    , Richmond Tx
    Ya, the trip along with everything was a pain, but it was in the winter and I wasn't busy then, so the timing was good. i still didn't get a spindle though. Both of them had routers.
    I have been thinking about upgrading to alpha and spindle, but then I may as well go with a tool changer, and then my vac hold down won't be enough, so the little upgrade gets real expensive in a hurry. lol
    I did find on my prs that shimming the rollers in and out on the gantry was a better way to square it than trying to keep fighting with the gantry bolts. It stays square now.
    Also don't get the gantry to close when you move the rails out. The motors\shafts or gears will hit the aluminum if you aren't carefull. Mine took quite a bit of tweaking.
    The new frames are weaker than your old steel table, so you will end up with the best of both worlds when you are done.
    Kenneth
    Kenneth
  4. #24
    Delray Beach, FL
    You are so right that one thing only leads to another. That's why I did this the way I am. I own the machine outright and didn't want to start another round of financing as much as I would like a new alpha. This economy and the narrow profits in it just can't justify it. Accumulating the parts bit by bit has made it a minor out of pocket expense and when I am done, I'm done.
  5. #25
    Sep 2008
    Why did you go with an extrusion on top of the c channel, for the new y car?
    Gene
    Vector Studio 22
  6. #26
    Delray Beach, FL
    I wanted to use hardened rails instead of the old mild steel that has a lot of miles on it. The new system needs more accuracy in straight and level so the combination of the hardened rails, heavy aluminum pillow and the extrusion is more precise. The rail is sized for the larger wheels I wanted to use as well. All together with the previous gecko upgrade it more closely mimics a newer model. Looks cool too!
    The overall object of the exercise is to cut more accurate box parts faster and eliminate all saw work with the possible exception of the 1/4" backs.
    And one more thing now that my work day is over:
    HAPPY 4TH OF JULY EVERYONE.
  7. #27
    Sep 2008
    Quote Originally Posted by bleeth View Post
    Thanks for the updates...
    Another cold one your way via the net,,,
    Gene
    Vector Studio 22
  8. #28
    Apr 2007
    Marquette, MI
    Dave...
    Looks good. I am tuned in on the progress.
    Looks like Gene got "el nombre del cervesa" correct this time!!
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
  9. #29
    Sep 2008
    Quote Originally Posted by islaww View Post
    Dave...
    ..hey
    que bueno que hablas espanol....
    pues quiero decir que los pacificos frios son los mejores en el mundo
    Gene
    Vector Studio 22
  10. #30
    Delray Beach, FL
    Heineken es el mejor pero si estoy en México es Dos XX es para mí!
  1. Mazes, continued....
    By Burkhardt in forum Project Ideas
    Last Post: 01-16-2015, 08:40 PM
  2. Bought and rehabbing a 2007 PRS-
    By GeneMpls in forum ShopBotter Message Board
    Last Post: 09-15-2013, 04:32 PM
  3. Value of my 2007 Bot
    By NickCorso in forum ShopBotter Message Board
    Last Post: 10-10-2010, 08:02 PM
  4. Probe Problems-(Continued)
    By myxpykalix in forum Archives2007
    Last Post: 05-10-2007, 12:06 PM
  5. Build your own table . . . . . . (continued)
    By gerald_d in forum Archives2006
    Last Post: 07-06-2006, 07:15 AM
