Results 1 to 10 of 12
Thread: Cutting angles
    Jun 2007
    Bedford Hills NY 10507
    Default Cutting angles
    How would i cut 45 miter or other degree edge with my bot?
    I need to cut a dresser that is essentially a trapezoid.
    thank for your input
    Erminio
    cnc routing, portland or
    45 is easy with a 90 degree v bit. but other angles you would either have to depend on the right angle of the bit or prop the piece up.
    Jun 2007
    Has anyone made a jig to accommodate a board order to cut various angles an the edge of a board?
    Jun 2004
    Green Acres Woodworking, North Bend Washington
    Ermino,
    Not sure that this is EXACTLY what you are looking for, but thought it might give you an idea.
    http://www.talkshopbot.com/forum/mes...312/22219.html
    Jun 2007
    Those vices are on the right track.I might get a pair for solid work.
    I need to cut angles on panel edges.I could do it on a table saw, but just wanted to know if anyone has cut them on a Bot.
    I think a larger jig,similar to your vices,just larger,would work.
    Jul 2006
    Zomadic LLC, San Francisco CA
    I've used a couple different solutions for this type of problem. In both cases I used the bot to construct it's own jig which then held the material at the proper angle and position. No hand measuring of any kind. The results were dead on.
    Problem #1: A 1/8" thru cut into a beveled edge - nothing is perpendicular.
    http://www.flickr.com/photos/zomadic...7594283371440/
    Problem #2: A very wide bevel in 1" ply. No pics of the jig - it was basically a ramp and I "surfaced" the bevel.
    Jun 2007
    Rob
    This is what I need to do.
    Can you explain how you cut to wide bevels.
    I would appreciate any help
    Erminio
    Jul 2006
    email coming your way.
    West Des Moines, Iowa
    I'm late to this discussion, but have photos of a jig I made for making angled cuts to the edges/ends of boards at www.iedu.com/DeSoto/Projects/Bevel/
    Hope this helps!
    Jun 2007
    Thanks Morris
    This will work.It would need to be enlarged to accommodate larger panels.I like the flexibility
    to adjust angles.Many of the angles I need are non
    standard.
    PS: You'll be hearing from me soon about your super zero.
  1. confusion (STILL) on angles...need help
    Last Post: 10-26-2016, 03:07 PM
  2. Calculating and cutting precise miter angles?
    Last Post: 10-24-2016, 10:25 PM
  3. Angles Other than 90
    By Chazz in forum ShopBot Desktop
    Last Post: 01-06-2014, 04:05 AM
  4. programming angles
    By chuckster in forum PartWorks
    Last Post: 10-14-2011, 03:22 PM
  5. Cutting Angles and threading
    By anothernewbie in forum Techniques for Cutting, Drilling, Machining
    Last Post: 10-03-2011, 07:55 PM
