I am trying to get a set of Prox switches to use in my shopbot but most online seem to be 12v supply and up and I think we need 5v. So which ones are the right ones to use. A model number would be nice.
Mike Purcell
Mike Purcell
Ask for metal sensor and explain your application to the electronic store representative. For homing/calibration, you want something that pretend a good repeatability.
Paco;
There is no electronic store in my area worth asking that question to. So Ebay or Digikey will be the supplier, so knowing exactly what I want is important. As far as I know I need inductive, 3 wire and 5v operating. Anything else?
Mike
Small, sealed, hardware adjustment included if possible...
This is something I recently bookmarked to look at later...
Google search
Do keep us post on what you go with...
Mike, I used Sunx model GL-8H for my prox switches. I am quite sure this is the same item that Shopbot used on the PRT. I got mine from Ranco. If you do a Google search for Ranco or Sunx it will lead you to contact info.
These are designed to run on 12 volts although I have seen them run on 5 volts. Just connect it to the 12 volt point on the terminal block.
Hope this helps.
Bill Thorpe
