Thread: How fast is too fast on Z for drilling...
    Habitat For Bats, Jackson GA
    Default How fast is too fast on Z for drilling...
    I'm predrilling holes in 1/2" ACX plywood (pine) with a 1/8" bit. The bit is a standard straight 2 flute bit and I can't imagine at 12,000 RPM that the wood offers any serious resistance. I'm running an HSD spindle and currently run at 1 ips for one plunge.
    From the experience gallery would I have a problem running at 2 ips, or 3 ips for the Z plunge? Should I peck drill? I only ask because I spend a fair amount of time predrilling. I don't want to damage the spindle, but I'd like to run as fast as possible.
    I know an air drill and second Z would be best for my projects... I'm saving up for that.
    Robert
    Robert,
    You should be fine running 2 IPS, you can save a considerable amount of time by keeping your safe Z around .25" or less. 12k RPM sounds about right, listen for stalling & burning. Adjust RPM accordingly. I don't think you need to peck, as this would just slow things down. I wouldn't go over 2 IPS with a 1:1 geared Alpha Z motor.
    Thanks! I'm running safe Z at .25" and jogging at 20 ips. I'm slowly tweaking these files faster and faster. I'll be running this revision shortly to see what happens.
    Robert
  1. How fast do you cut in 3D?
    By blackhawk in forum Techniques for Cutting, Drilling, Machining
    Last Post: 08-17-2013, 04:51 AM
  2. How fast can you cut?
    By Blacknbart in forum ShopBot Businesses
    Last Post: 02-01-2011, 08:00 PM
  3. How Fast Can I cut .080 Aluminum??
    By tim_whitcher in forum Archives2005
    Last Post: 07-11-2005, 05:06 PM
  4. How fast is too fast?
    By sawkerf in forum Archives2005
    Last Post: 01-31-2005, 06:17 AM
  5. Computer - how fast is fast enough?
    By rhfurniture in forum Archives thru2004
    Last Post: 10-28-2004, 10:12 AM
