What are you using for Jog speeds and cut speeds for
your PRS standard?
I've been cutting at 3.5 in/sec
Jog at 4.25in/sec
Anything faster and I start losing steps.
Wonder if I can bump it up a bit.
your PRS standard?
Jog at 4.25in/sec
I just surfaced my table jujst before getting on now and I was at 5.5 IPS with no lost steps. I can jog at 8 IPS
So how can I up my speeds?
I lost steps at lower speeds also. Once I updated my software I found cutting at 5+ IPS is not a problem. However, still tend to run slower because I am concerned about the Vacuum hold down letting go (feins).
Larry
Erminio...
I dont have the complete answer, but check these and improve where you can.
Speed test and make sure you are mid 70's+ add USB2 hub and shielded cable
Use the latest software
Make sure your computer is faily fast dual core, etc and no less than 1 gig of ram.
Turn off anything you can in XP and have it still run. CHeck out BLackViper.com for help
Gary
Erminio,
I surface my table at 8 ips and have the same machine. I cut about the same speeds you do. When I jog over 10 it starts getting unreliable.
I think the machie will run quicker and you need to look at all the PC things that could slow you down.
Kenneth
Thanks Guys!
I my comm after speed test is about 86%
Not bad
I have been using 3.6.14 since it's release.
I've had everything off in XP
Only thing left is the computer
Ultimate solution- upgrade to Alpha
(maybe when business picks up!)
I'll keep you posted
Erminio
Drop back to 3.5.9 That is what I am running and I get better speeds without the lost steps. I tried 3.6.12 and I start loosing steps when I get up to 4.5 IPS while surfacing my table.
I'll give a try,Jerry.Though I had the same issue with previous versions.
I was jogging @ 6"/sec all was fine for a while,then suddenly the gantry jammed and lost steps.
Seems to happen in the same vicinity.
No problems jogging @ 4.25"/sec
I do have a PRS Drill attached.
I was wondering if the added weight might be a factor.
Not a big problem.Just trying to find a solution.
