Results 1 to 9 of 9
Thread: PRS Standard Jog /Cut speeds
    Jun 2007
    Bedford Hills NY 10507
    Default PRS Standard Jog /Cut speeds
    What are you using for Jog speeds and cut speeds for
    your PRS standard?
    I've been cutting at 3.5 in/sec
    Jog at 4.25in/sec
    Anything faster and I start losing steps.
    Wonder if I can bump it up a bit.
    I just surfaced my table jujst before getting on now and I was at 5.5 IPS with no lost steps. I can jog at 8 IPS
    Jun 2007
    So how can I up my speeds?
    Jan 2006
    , Depew New york
    I lost steps at lower speeds also. Once I updated my software I found cutting at 5+ IPS is not a problem. However, still tend to run slower because I am concerned about the Vacuum hold down letting go (feins).
    Larry
    Apr 2007
    Marquette, MI
    Erminio...
    I dont have the complete answer, but check these and improve where you can.
    Speed test and make sure you are mid 70's+ add USB2 hub and shielded cable
    Use the latest software
    Make sure your computer is faily fast dual core, etc and no less than 1 gig of ram.
    Turn off anything you can in XP and have it still run. CHeck out BLackViper.com for help
    Gary
    Dec 2008
    , Richmond Tx
    Erminio,
    I surface my table at 8 ips and have the same machine. I cut about the same speeds you do. When I jog over 10 it starts getting unreliable.
    I think the machie will run quicker and you need to look at all the PC things that could slow you down.
    Kenneth
    Jun 2007
    Thanks Guys!
    I my comm after speed test is about 86%
    Not bad
    I have been using 3.6.14 since it's release.
    I've had everything off in XP
    Only thing left is the computer
    Ultimate solution- upgrade to Alpha
    (maybe when business picks up!)
    I'll keep you posted
    Erminio
    Drop back to 3.5.9 That is what I am running and I get better speeds without the lost steps. I tried 3.6.12 and I start loosing steps when I get up to 4.5 IPS while surfacing my table.
    Jun 2007
    I'll give a try,Jerry.Though I had the same issue with previous versions.
    I was jogging @ 6"/sec all was fine for a while,then suddenly the gantry jammed and lost steps.
    Seems to happen in the same vicinity.
    No problems jogging @ 4.25"/sec
    I do have a PRS Drill attached.
    I was wondering if the added weight might be a factor.
    Not a big problem.Just trying to find a solution.
  1. Mdf speeds
    By RSP in forum Designing and Creating the sbp cutting file
    Last Post: 05-20-2015, 03:15 PM
  2. 2008 PRS standard running 3.8.10 move speeds.
    By gundog in forum ShopBotter Message Board
    Last Post: 01-28-2014, 04:01 AM
  3. MAX Speeds for PRT Standard??? (NO 4G)
    By tuck in forum ShopBotter Message Board
    Last Post: 02-14-2012, 11:30 AM
  4. Feed Speeds for MDF on PRS Standard
    By jdervin in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-30-2010, 12:11 AM
  5. PRT 96 speeds
    By bill_flesher in forum Archives2006
    Last Post: 04-19-2006, 01:19 AM
