Results 1 to 5 of 5
Thread: Radius question......ANOTHER
    David Marcotte Svc LLC, Cocoa Fl.
    Default Radius question......ANOTHER
    I have a new customer that uses large radius pieces of plywood. The latest was 167" with a 6" wide plate,,making the inside radius 161"
    My concern now is......how can I figure how to make the end cuts so the parts can be placed end to end to make a circle without field cutting the angle on the ends?
    I was placing two radius' 6" apart and using a poly line slicing through the ends from a height of the radius at the center point on the plywood.
    The angle was incorrect.
    Second time I made the outer radius then offset inward 6" then I snapped a polyline to connect the parts. Not sure if this is right.
    I could sure use some help on this....thanks for any help.
    David
    Apr 2007
    Marquette, MI
    David....
    I just tried this to make sure...
    Make a 167" rad circle centered at x=48 y=-119
    offset 6" to inside
    open polyline tool with first point at 48,-119
    you can either drag the other end to maximum available on the sheet or select a degree amount if you are looking for an even number of pieces to get a full circle. this pic shows 2 lines 26.5 degrees either side of vertical. (max length from sheet (+/-)
    If you need exact pieces to make a circle you will need to select angles that have multiples that equal 360 (i.e. 6 pcs @ 60 degrees = full circle)
    Node edit and remove all unwanted vectors.
    In any event as long as the start point of the line is at the center of the circle... all will fit together.
    Gary
    Duncan, British Columbia, Canada
    David,
    I use AutoCAD for this kind of thing because I'm a lot quicker at it. I drew a circle with a 167" radius and offset it inwards 6".
    I then drew a line from the centre of the circles straight up. After that I did some trial and error polar arrays to see how many array segments it took to get an arc that would fit on a sheet of plywood.
    It took 12 segments which results in a 30 degree angle on the ends.
    I trimmed one segment out of the circle and copied it on the outline of a 4'x8' sheet of plywood. I got 6 segments on 1 sheet.
    I've attached a .dxf of that layout that you can use if you like. You'll need 2 sheets to complete the circle.
    How are the segments joined in the field? If you put Rob Bell's puzzle joint on each end they would go together nicely.
    Let me know if you want some help with that.
    167" radius segments
    167 radius segments.dxf (24.9 k)
    Winter Park FL
    I would like to access Scotts file but I can't save it. I have AutoCAD. What am I doing wrong.
    right click once on it
    click "save target as"
    it comes up as:
    167_radius_segments-38780.unk
    change the filetype designation from .unk to .dxf and save it where you want.
  1. Radius Corner
    By pappybaynes in forum Troubleshooting
    Last Post: 04-27-2014, 11:13 AM
  2. radius on a vector
    By tracys in forum ShopBotter Message Board
    Last Post: 05-29-2013, 09:13 PM
  3. Best Radius
    By alan in forum Sign Making
    Last Post: 03-17-2013, 08:11 AM
  4. RADIUS HELP NEEDED
    By coach in forum Techniques for Cutting, Drilling, Machining
    Last Post: 01-28-2009, 07:16 PM
  5. How do I put a radius on a rectangle in X3
    By ed_lang in forum Corel
    Last Post: 05-17-2007, 06:34 PM
